Robotics Market Growth Expected Through 2030
Increasing adoption of robots in various industries will drive future growth for this market, presenting opportunities for fluid power and electromechanical technology suppliers serving the robotics sector.
Key Highlights
  • The robotics market is projected to grow over the next 5 years as more industries and applications adopt automation.
  • Cobots will see the largest growth in the years ahead as the barrier to entry improves as well as safety and ease of use for these robots.
  • Growth in the robotics market will also drive growth for robotic grippers, presenting opportunities for fluid power and other technology suppliers.
At Automate 2026, robots could be seen just about everywhere you looked. From small mobile robots used for transporting boxes and other objects to large industrial robots capable of moving a car door.
The market intelligence firm is predicting that material handling and assembly will be the applications in which industrial robots will be used most in the years ahead to aid with increasing demand for efficient logistics and precise assembly of manufactured goods.
Interact Analysis’ expected robot shipment average annual growth rates by global market from 2025-2030 are:
  • Asia-Pacific (APAC) – 7.1%
  • North and South America – 6.2%
  • EMEA (Europe, the Middle East and Africa) – 4.7%.
Logistics, new energy and semiconductors are the sectors that will drive global shipment growth.
Although the automotive sector has been a strong driver for the robotics industry over the years, Interact Analysis and A3 both note reduced demand from this sector in North America and EMEA due to the weaker market conditions it has experienced in recent years.
Despite this, Interact Analysis is anticipating automotive to remain the largest sector for global shipments of industrial robots through 2030.
Interact Analysis also anticipates rising use of artificial intelligence (AI) to aid industrial robot growth. Integration of AI into robotics systems will continue to improve their capabilities and use cases. In addition, they are playing an important part in the production of the semiconductors and data center equipment necessary for AI’s operation.
Cobots Will be Fastest Growing Segment for Global Robotics Market
Both A3 and Interact Analysis note cobots as the strongest segment of the robotics market. Collaborative robots (cobots) are a type of industrial robot but are designed to work alongside human labor. The larger articulated versions many see in manufacturing facilities are usually behind cages or other safety structures.
Cobots can be placed along a production or assembly line to help with packaging, material handling, quality inspection, sorting and other tasks, making them a versatile and relatively easy-to-adopt option for many operations.
In its first-quarter 2026 robot order report, A3 noted that collaborative robots were the strongest performing category. This was the case for much of 2025 as well, with the association reporting that full-year cobot orders accounted for 19.6% of total robot orders during the year.
While Interact Analysis foresees articulated robots remaining the largest robotics segment through 2030, cobots will experience the fastest growth.
The firm reports that in 2025 cobot shipments were 14.5% above those from the previous year. And it is projecting further growth in the years ahead.
An annual shipment growth rate of 17.3% is expected for these smaller robots, while articulated robots will be 5%. Falling barriers to entry, improved safety, ease of use and cost reductions all contributed to increased cobot shipments in 2025, factors that are likely to aid future growth for this segment as well.
China is predicted to be the dominant market for cobot shipments through 2030, followed by the Americas and EMEA.
According to Interact Analysis, the industry is also starting to shift toward the creation and use of medium and heavy payload cobots. Cobots are typically used for lighter payloads of 10 kg (22 lbs.) or less, but newer models are reading payloads of 16-20 kg (35-44 lbs.) and higher, increasing their use cases and thus market growth potential.
Read the article “Cobot Market to Grow as Adoption in Various Industries Rises” to learn more about the continued growth expectations for collaborative robots.
Robotic Grippers Market to Rise in Tandem with Continued Robot Uptake
An important component of many cobots and other industrial robots is the gripper which is used to pick up and move objects. This is where pneumatics is often used within the robotics industry, as well as electric technologies and even hydraulics.
With uptake of robots continuing to rise, so too will the need for robotic grippers. As such, research firm Valuates Reports is projecting the global robot grippers market will achieve a compound annual growth rate (CAGR) of 18.4% through 2031.
Pneumatic grippers are expected to account for the largest segment of the market at 60%, including vacuum grippers.
While use of electric technologies is increasing, many of the pneumatics companies I spoke with at Automate said they are still seeing opportunities for this fluid power technology in the robotics sector. Increasing integration of electronics to create so-called smart gripping technologies is helping to improve the capabilities of pneumatic grippers which will aid their continued use in the market.
Per Valuates Reports, the need for flexible handling systems in various automated operations — such as production, warehousing, packaging, inspection, assembly and material transfer — is a key driver for the expected growth of the grippers market.
Sara Jensen
Sara Jensen
