Toothed belt cylinders
ZR rodless cylinders have a completely enclosed sealing system that prevents contaminants from entering pressure chamber. They synchronize two or more cylinders via output shafts and are available in 25- or 40-mm bores with stroke lengths to 4500 ...
ZR rodless cylinders have a completely enclosed sealing system that prevents contaminants from entering pressure chamber. They synchronize two or more cylinders via output shafts and are available in 25- or 40-mm bores with stroke lengths to 4500 mm. They feature an internal seal for harsh and dirty environments, a static brake, and optional slide or roller guides.
Airtec Pneumatics Inc.,
(630) 543-0265,
www.airtec-usa.com
