Edited By Mary C. Gannon Senior Associate Editor Zurcon Z25 polyurethane material offers viscoelasticity and high tensile strength at extreme temperatures to 130°C (270°F). It provides improved extrusion resistance and compression set for hydraulic ...
Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2013 04 Zurcon Z25
Zurcon Z25 polyurethane material offers viscoelasticity and high tensile strength at extreme temperatures to 130°C (270°F). It provides improved extrusion resistance and compression set for hydraulic applications and is ideal in heavy-duty cylinder sealing applications, such as industrial and mobile applications with limited cooling systems or cylinders exposed to high-temperature painting processes. It is self-energizing, operates at pressures to 40 MPa/ 5800 psi without a back-up ring, is suitable for use in all hydraulic fluids, and has a low compression set.
