Pneumatic swing clamp
Swing clamp arm rotates 90° as it extends up away from the work piece, providing clearance and access for loading and unloading. Double-acting operation, standard magnetic piston, and optional magnetic sensors enable positive cycles and work ...
Swing clamp arm rotates 90° as it extends up away from the work piece, providing clearance and access for loading and unloading. Double-acting operation, standard magnetic piston, and optional magnetic sensors enable positive cycles and work piece detection features. Extruded aluminum body mounts directly and rigidly to equipment surfaces in a minimum of space.
Fabco-Air Inc., (352) 373-3578, www.fabco-air.com
