Tube Cleaning
Internal tube cleaning system for cylinders comes with 20-gal filter cart and 50-ft hose reel. It is available with two wash heads from 3 to 7 and 6 to 18 in. diameter ranges. Comes with attachment to use a flapper wheel to polish the bores to 50 ft in length. It can be used in the shop or for field service to polish then clean cylinder bores.
Machinery Service & Design (262) 513-8040
www.ms-d.com
