Linear position feedback devices
High accuracy, non-contacting linear position feedback devices for use in cylinder-embedded hydraulic and pneumatic mechanisms use magnetostrictive technology. Remote or field-programmable pressure transducers are available with broad pressure ranges, resolution and hysteresis of ±0.01% full scale, high corrosion resistance. and custom configuration of fittings and connectors.
Sensor Systems LLC, (727) 347-2181, www.vsensors.com
