Series 319 oil-less, WOB-L piston dc pump and compressor is small and lightweight (5.1 lb/2.3 Kg). Die-cast aluminum components provide strength and durability. It provides up to 150 psi (10.4 bar) of maximum intermittent pressure, and 93% local barometer of maximum vacuum. Corrosion resistant e-coated exterior finish, stainless steel inlet valve, thermally protected motor and inlet filter/exhaust muffler all provide quiet operation. It is available with 12 and 24 Vdc motor and dryer/solenoid.
Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2013 01 Thomas 319 Series
It is best suited for mobile applications including air suspension, air doors, air horns, air brakes and clutches and fuel systems. It includes EMI suppression and is RoHS compliant.
Thomas Division, a Gardner Denver Co., (920) 457-4891, www.gd-thomas.com
