Solenoid Valve Connectors
Series 5F and 5J DIN solenoid valves have a completely molded design for high environmental integrity over field wire versions. They come with captive screw and molded in gasket with assembly and low profile straight line or right angle ...
Series 5F and 5J DIN connectors for solenoid valves have a completely molded design for high environmental integrity over field wire versions. They come with captive screw and molded in gasket with assembly and low profile straight line or right angle configurations for installation in limited spaces. They are available in ISO, Mini, 8-, and 9.4-mm sizes, with or without indicator light, and 6- or 15-ft standard wire lengths; custom wire lengths and hard usage cable are available.
Canfield Connector, (330) 758-8299, www.canfieldconnector.com
