Push-Lock Hose Assembly
The 409B EZ-ON hose press features thrust and ball bearings for smooth operation, a new drive screw and larger nut for improved performance, and a traveling carriage with sealed bearings that rolls on a track for better stability. It installs both straight and angled fittings from ¼ to 1 in. in seconds. A stationary vise secures the fitting and a travelling carriage clamps the hose. The hose is then easily installed by turning the drive screw with a ratchet or impact gun.
Koul Tools, (928) 854-6706
