Tension bushings
Tension bushings are available in standard and custom versions for providing a bearing surface between cylinder clevis pins and housings. Their full-length longitudinal slot permits compression
and expansion, and their chamfered ends facilitate easy installation and removal. They are available in ODs ranging from ¾ to 3½ in., in three wall thicknesses (1⁄8, 3⁄16, and ¼ in.), and lengths ranging from ½ to 3 in. Standard materials include through-hardened and tempered high carbon spring and/or alloy steel. Metric sizes are also available.
Vogelsang Corp., (732) 364-0444,
Click here for more information.
