Stopper cylinders
Stopper cylinders are offered in 32, 40, and 50 mm bores and seven rod end styles. Direction of rollers is adjustable. Magnetic pistons allow mounting of magnetic sensors to cylinder surfaces when input signals are required for controllers. They come as single or double acting with spring extended rod. Double acting models feature optional built-in fail-safe extended rod. Shock absorbers serve as safety stops.
Fabco-Air Inc., (352) 373-3578, www.fabco-air.com
