PRO-6H joystick has the long life cycle of a non-contacting Hall-effect proportional output device in a sturdy mechanical design. Single-axis joystick is highly resistant to EMI and has standard proportional 0.5- to 4.5-Vdc output with optional custom-engineered PWM circuits. Its 10-mm handle shaft fits a variety of handle configurations, including triggers, rocker switches, pushbuttons and thumb wheels.
Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2013 01 J r Merritt Pro 6 H
PRO-6H joystick has the long life cycle of a non-contacting Hall-effect proportional output device in a sturdy mechanical design. Single-axis joystick is highly resistant to EMI and has standard proportional 0.5- to 4.5-Vdc output with optional custom-engineered PWM circuits. Its 10-mm handle shaft fits a variety of handle configurations, including triggers, rocker switches, pushbuttons and thumb wheels. Field-adjustable friction brake with positive center detent is suitable when speed must remain constant under continuous shock and vibration.
Mechanical interlock is available. It is suitable for use on scissor lifts, aerial work platforms, bucket trucks, cranes, agricultural, mining and forestry equipment.
