Accelerometer Alarm Transmitter
Model 682A08 vibration transmitter is an ICP accelerometer signal conditioner, complete with dual semiconductor relay alarms and 4-20 mA signal transmission, for continuous monitoring of unbalance and misalignment. Module provides ...
Model 682A08 vibration transmitter is an ICP accelerometer signal conditioner, complete with dual semiconductor relay alarms and 4-20 mA signal transmission, for continuous monitoring of unbalance and misalignment. Module provides excitation power for 100 mV/G ICP accelerometers, and can integrate the signal into velocity. It comes with selectable low pass filters at 1 kHz or 10 kHz, and high pass filters at 3 Hz or 10 Hz.
PCB Piezotronics, IMI Sensors Div.
(800) 959-4464
www.pcb.com
