Thomas 2220 series brushless dc oil-less air compressor is designed for medical and other applications requiring a compact, lightweight compressor with variable output. It is small — 3.77 in. high × 2.64 in. wide × 4.70 in. long — and weighs only 1.48 lb (0.7 kg).
Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2012 12 Thomas 2220 Series
Thomas 2220 series brushless dc oil-less air compressor is designed for medical and other applications requiring a compact, lightweight compressor with variable output. It is small — 3.77 in. high × 2.64 in. wide × 4.70 in. long — and weighs only 1.48 lb (0.7 kg). Efficient variable speed motor produces flow to 1.1 cfm (32.3 lpm) and pressure to 30 psi. (2.1 bar). WOB-L piston technology combined with the enclosed crankcase design provides quiet (45 dB(A)) performance.
