Miniature piloting solenoid valve
Miniature 3-way high flow piloting solenoid valve reduces space and weight while improving reliability and performance. It is available in a single coil configuration, weighs 4 oz and uses 7.8 W at 28 Vdc. It is rated for minimum flow of 4 gpm at maximum pressure of 3000 psi. Plunger design in magnetic circuit provides an efficient force/stroke relationship. Multi-Seal technology eliminates Orings and back-up rings and simplifies port layout by allowing two ports to be sealed in the same axial plane.
The Lee Co., (860) 399-6281, www.theleeco.com
