Fluid Contamination Prevention Kits
Contamination prevention FlowGuard Hydraulic Adapter Kits consist of a disposable desiccant breather, single-position vacuum indicator, optional sample port, customizable fill tube, and fill and drain quick connectors. Silica gel changes from blue ...
FlowGuard Hydraulic Adapter Kits consist of a disposable desiccant breather, single-position vacuum indicator, optional sample port, customizable fill tube, and fill and drain quick connectors. Silica gel changes from blue to pink as moisture adsorption is reached. Breathers retain particulate down to 0.5 μm or 3 μm absolute, are rated for 16 cfm, and have a 1-in. threaded standpipe. Three sizes — DC-2, DC-3 and DC-4 — suit many mounting needs.
Des-Case Corp., (615) 672-8800, descase.com
