Cut back on piping and fittings
A series of filter-regulator-manifolds provides up to eight filtered and regulated air outlets from a single air inlet. The easy-to-connect manifold reduces the amount of piping and fittings. The units provide full flow to each port, allowing pressure to be set at the actuator without accounting for leaks. Quick-connect fittings reduce system installation and service time. The filter regulators come in four, six, or eight outlet ports in sizes between 1 /8 and 3 /8 in. Standard flow capacities range from 10 to 70 scfm. A variety of bowl sizes, inlet portings, and elements are offered.
Monnier Inc.,
(810) 794-4935,
www.monnier.com
