Quick change LDT
In-cylinder magnetostrictive linear displacement transducer has Rapid Replacement Module to cut downtime and make change-out of transducer electronics quick and easy without removal of pressure tube from hydraulic cylinder. Reduces risk of oil spillage; ...
In-cylinder magnetostrictive linear displacement transducer has Rapid Replacement Module to cut downtime and make change-out of transducer electronics quick and easy without removal of pressure tube from hydraulic cylinder. Reduces risk of oil spillage; eliminates need to bleed air from system.
Balluff Inc.,
(800) 543-8390,
www.balluff.com
