Linear Position Sensors Target Port-Mounted Applications
MR series of linear position sensors are intended as a replacement for magnetostrictive sensors, specifically targeting port-mounted applications.
MR series of linear position sensors are intended as a replacement for magnetostrictive sensors, specifically targeting port-mounted applications. This series features ranges from 4 to 36 in.; operates to 5,000 psi or 10,000 ft. in depth; has operating temperatures of 85°C for standard products and 105°C for custom. MR series also features DC voltage or analog output and SenSet Field Adjustable Scaling.
Alliance Sensors Group., (856) 727-0250
