Miniature encoders
TRD-MX Series of Koyo miniature encoders provides a cost-effective solution for size-limited applications. Light-duty encoders feature a small body with 25-mm diameter and 29-mm depth. Constructed with a 4-mm diameter solid shaft, they offer resolutions from 100 to 1024 pulses/rev.
TRD-MX Series of Koyo miniature encoders provides a cost-effective solution for size-limited applications. Light-duty encoders feature a small body with 25-mm diameter and 29-mm depth. Constructed with a 4-mm diameter solid shaft, they offer resolutions from 100 to 1024 pulses/rev. They are fitted with a 2-m cable with tinned ends and are available with either 5 to 12 or 12 to 24 Vdc open-collector or 5 Vdc line-driver outputs; the series provides up to 100 kHz response frequency.
AutomationDirect, (770) 889-2858, www.automationdirect.com
