Magnetostrictive sensors
Edited By Mary C. Gannon Senior Associate Editor MLW series of long stroke linear position sensors provides accurate absolute position measurement of displacements up to 1.2 m. They are available in ranges of 300 to 1200 mm, for hydraulic ...
MLW series of long stroke linear position sensors provides accurate absolute position measurement of displacements up to 1.2 m. They are available in ranges of 300 to 1200 mm, for hydraulic cylinder and actuator feedback applications where the sensor can be mounted externally or embedded into a cylinder or actuator body. Probe is sealed to 5000 psi. They are powered by 24 Vdc, and have less than ±0.25% linearity and ±0.01% repeatability FS with outputs that include analog voltage, current and SSI.
Macro Sensors
(856) 662-8000
www.macrosensors.com
