Magnetic angle sensor
PRAS2 magnetic angle sensor comes in a 20-mm flat, 36-mm diameter servo flange housing. It is a contact and wear-free sensor that uses an external permanent magnet to measure complete angular position from 0° to 360° with a typical resolution of 0.1°. It is available with three different analog outputs: 4-20 mA, 0.5-4.5 V, and 0.5-10 V. Angle measurement circuitry is shielded from external environment conditions. It is highly shock- and vibrationresistant.
ASM Sensors Inc., (630)-832-3202, www.asmsensors.com
Related
Supplier Submitted
