Magnetic inclinometer
Positilt PTAS2 inclinometer features an IP68-rated stainless-steel housing and is available with three absolute analog outputs: 0.5-5 V, 0.5-10 V and 4-20 mA with a typical resolution of 0.1°. Measurement is available from ±15° to ±180° in 15° increments. Compact 1.7-in. diameter housing with servo flange mounting allows for quick and easy installation. Wear-free, multi- Hall Effect position sensor technology increases reliability in extreme environments. It withstands 100 G shock and 20 G, 10 Hz-2 kHz vibration.
ASM Sensors Inc., (630)-832-3202, www.asmsensors.com
Circle 159
