Pressure sensors
Industrial grade ICP pressure sensors come in full-scale ranges from 100 to 5000 psi and sensitivities from 1 to 50 mV/psi. They feature all-welded, stainless-steel construction and a 1 /4 NPT pressure fitting. Built-in microelectronic circuitry delivers clean, voltage output signal. Electrical case isolation provides shielding from electromagnetic fields and eliminates ground loop problems. They are available with a 2-pin MIL connector or integral, molded, submersible cable assembly.
PCB Piezotronics Inc., Pressure Div., (888) 684-0011, www.pcb.com
Related
Supplier Submitted
