Vacuum lifter
VPF-57 compact, below-the-hook vacuum lifter handles cylindrical, nonferrous materials, such as billets, pipe, and castings. It features a suction pad with foam seal. Optional spring-loaded parking stands protect the foam pad when not in use; custom pads can handle up to 2000 lb. It is offered in compressed air and electric powered versions.
Anver Corp., (800) 654-3500, www.anver.com
