Clippard Minimatic Electronic valves and manifolds provide a complete system for efficient interface with electric and electronic circuits for many applications. They provide an air flow of 1.4 scfm @ 100 psig, more than twice the flow of Clippard’s trusted EC/EV/ET valve series. Optional 1.1 scfm @ 50 psig and 0.95 scfm @ 25 psig flow models are also available.
Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2013 03 Clippard High Flow Valves
Minimatic Electronic valves and manifolds provide a complete system for efficient interface with electric and electronic circuits for many applications. Standard models provide an air flow of 1.4 scfm @ 100 psig, more than twice the flow of EC/EV/ET valve series. Optional 1.1 scfm @ 50 psig and 0.95 scfm @ 25 psig flow models are also available. Precision-built, 2-way normally-closed control valves use a unique valving principle with no sliding parts. Complete poppet travel is only 0.007 in., resulting in low power consumption and exceptionally long life.
Manifold and in-line mounting are available as well as many different electrical connection styles. Oxygen Clean and Analytical versions are also available as well as FKM, EPR and Silicone seals, and diodes.
