Stainless-steel pilot valves
The 8361 series of …-in., NPT, 3-way, stainless steel pilot valves eliminates stiction problems that can occur in control valves installed in pneumatic logic panels that control monitoring safety systems in offshore oil and gas production. ...
Models include manually operated, airpiloted, and solenoid-piloted. They can be configured as breathing and nonbreathing. Balanced design maintains flow of 1.4 CV when the valve is used in a normally open or normally closed configuration.
ASCO Numatics
(800) 972-2726
http://bit.ly/HP1011ASCO
