Proportional air valve manifold
Manifold is used with Watson Smith series of VP12 miniature proportional valves and is DIN rail mountable. It easily integrates into the air regulation system and is configurable from the left or right. It is supplied with built-in push-in fittings and operates from 4 to 20 mA or 0 to 10 V for pressures to 120 psi.IMI Norgren Inc., (303) 794-2611, www.norgren.com
