Medium pressure check valves
CP/CPA series check valves have max working pressure of 3000 psi in ¼- or ½-in. sizes. CP series has factory-set fixed cracking pressure; CPA series is adjustable. Both are and made of 316 stainless. Color-coded deflector caps provide easy identification of line pressure, system cracking pressure, or system media. The caps are machined from durable aluminum and anodized with colors to comply with EN 1089-3. Available in 18 cracking pressures to 100 psi. SSP, (330) 425-4250, www.my-ssp-usa.com
