Edited By Mary C. Gannon Senior Associate Editor DT line of high-performance hydraulic cartridge filters are available for construction equipment, hydro-static drives, transmissions, bearing lube oil systems and other heavy-duty ...
Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 04 01 2011 87217hydraulicc 00000059866
DT line of high-performance hydraulic cartridge filters are available for construction equipment, hydro-static drives, transmissions, bearing lube oil systems and other heavy-duty applications. They provide 73% higher dirt-holding capacity and 47% lower initial pressure drop than traditional filters. Synteq media technology allows high initial cleanliness and system protection. They reduce maintenance cost by extending filter life which, in turn, results in longer change intervals.
