The Role of Hydraulic Filtration is Evolving
Cory Gray of Eaton Filtration discusses how hydraulic filters are going beyond particle collection to now playing an important part in machine health management.
Key Highlights
  • Cory Gray, Global Sales Director for Eaton Filtration, offers his insights on how hydraulic filtration technology is evolving into an important component within machine health management systems.
  • In addition to particle collection, machine owners are looking for filtration solutions that can provide visibility into particle counts, oil condition and other factors that might contribute to unplanned downtime.
  • New hydraulic fluid formulations and filter designs that can provide uninterrupted operation are also contributing to the continued evolution of hydraulic filtration.
Filters have always played an important role in maintaining the cleanliness of hydraulic fluids. They trap contaminants that may be in these fluids, preventing potential damage to sensitive components such as pumps and valves.
But like many components in modern hydraulic systems, filters are being tasked with doing so much more.
As Cory Gray, Global Sales Director for Eaton Filtration, explains in this Q&A with Power & Motion, hydraulic filters are no longer just a static component. Instead, they are becoming a part of the overall machine health-management system.
Besides keeping particles out of hydraulic systems, he said customers also want more visibility into their systems, such as oil condition and particle counts. This allows for better insight into potential maintenance issues before they cause a costly downtime issue.
Power & Motion spoke with Gray about how this is influencing hydraulic filtration designs as well as other factors shaping filter developments.
*Editor’s note: Questions and responses have been edited for clarity.
Power & Motion: What new technological developments have you seen come into the hydraulic filtration market in the past 2-3 years, and what prompted these developments?
Cory Gray: One of the more important changes is that hydraulic filtration is being treated less like a static component and more like part of the machine’s overall health-management strategy.
The filter’s job will always be defined as “keeping particles out,” but now customers are asking for more in terms of better visibility into oil condition, more predictable service intervals and filtration architectures that do not force equipment offline for routine maintenance. That is why we’re seeing more use of electronic differential pressure monitoring, clogging indicators and condition-based maintenance tools.
At Eaton, that same shift is reflected in products such as the VS6 electronic differential pressure sensor, which is designed to provide operators with a more precise indication of when a filter may need attention, instead of relying only on visual inspection or fixed replacement schedules. This can help customers reduce unnecessary element changes while also mitigating the risk of running a filter too long, depending on the application and operating conditions.
We are also seeing more attention paid to uninterrupted operation. Duplex and changeover filter designs are gaining importance because many hydraulic and lubrication systems are difficult or costly to stop solely to service a filter. Eaton’s recent DUA, LWF and DNR series filters are examples of this direction — they are designed for demanding applications such as power generation, manufacturing and marine systems, with duplex configurations intended to allow element changeout while filtration continues, subject to proper installation, operation and maintenance.
What prompted all of this is straightforward: downtime has become more expensive, systems are operating at higher utilization rates, and many hydraulic components are increasingly sensitive to contamination.
Customers are not just asking, “Will this filter protect the pump?” They are asking, “Will this filtration strategy help me keep the system running, control maintenance costs and make better decisions before a failure occurs?”
Power & Motion: What are some of the key features or capabilities customers are desiring in hydraulic filtration technology today?
Cory Gray: From a technical standpoint, three things come up repeatedly:
  • High dirt-holding capacity, so filters last longer and require fewer changeouts.
  • Stable, low differential pressure (ΔP; kept as low as practical) to maintain consistent flow, minimize energy losses and reduce stress on system components.
  • Fine filtration efficiency, particularly for the smaller particles that drive wear.
But beyond performance, there’s also a strong push for operational flexibility. Customers want solutions that can be integrated into existing systems, configured for different pressure ranges or flow paths and maintained without shutting down production.
Power & Motion: What are some of the biggest challenges customers face with their hydraulic filtration technologies, or come to Eaton looking for guidance on?
Cory Gray: A common challenge is finding the right balance between filtration efficiency, flow performance and element life.
Customers often know they need cleaner oil, but the answer is not always to move to the finest possible micron rating. If the filter is too restrictive for the system, differential pressure can rise quickly. That can reduce flow, increase energy demand, open bypass valves, create cold-start issues or, in some severe cases, contribute to oil starvation at pumps and other critical components.
That is why Eaton evaluates the full operating profile, including flow rate, viscosity, temperature, pressure, duty cycle, contamination load and target cleanliness level, before recommending a filtration approach.
Another challenge is the variability in contamination, as hydraulic systems rarely encounter a consistent contaminant profile. Particles can come from component wear, ingression through breathers or seals, poor fluid handling, new oil that was not adequately filtered before filling, maintenance activity, hose or pipe debris and environmental exposure. A filter setup that performs well in a controlled test condition may struggle when the system sees spikes in particulate load, water contamination, varnish precursors, or changes in oil viscosity.
Customers also come to us for help with filter placement and system architecture. Pressure-line, return-line, suction-side and offline kidney-loop filtration all do different jobs. A pressure filter may protect a sensitive servo valve or actuator, while return-line filtration helps clean the oil before it re-enters the reservoir. Offline filtration can continuously polish the reservoir fluid without depending on machine cycle flow. The right answer is often a combination rather than a single filter element.
Maintenance strategy is another major issue. Many facilities still change elements by calendar interval, which can mean replacing filters too early or running them too long. Eaton helps customers evaluate condition-based maintenance using differential pressure indicators, electronic sensors and oil analysis so they can better understand when an element is loading and how the system’s cleanliness is trending.
Finally, customers are asking for help translating cleanliness targets into practical system design. They may know they need to meet a specific ISO cleanliness code, but they need guidance on beta ratio, micron rating, dirt-holding capacity, bypass settings, seal compatibility, pressure rating and element construction. That’s where filtration moves from a component selection exercise to an application engineering decision. The goal is to match the filtration strategy to the machine, the fluid and the associated risk profile.
Power & Motion: How, if at all, are new formulations of hydraulic fluids — such as zinc-free and biodegradable options — impacting hydraulic filter designs?
Cory Gray: They are definitely influencing filtration decisions, especially around media compatibility, additive retention and fluid life.
Traditional hydraulic oils have long relied on zinc-based, anti-wear additive packages (particularly zinc dialkyldithiophosphates or ZDDP). As more customers evaluate zinc-free, ashless, or biodegradable fluids, we have to account for different chemistries. These fluids can have different properties when it comes to viscosity, how well they mix with water, how stable they are against oxidation, how likely they are to foam and how additives affect filter media.
From a filter design standpoint, compatibility becomes critical. The filter element should be selected to remove harmful particulate contamination while minimizing adverse effects on useful fluid additives, based on the applicable fluid chemistry and system requirements.
Biodegradable fluids can add another layer of complexity as some ester-based fluids, for example, may be more sensitive to moisture, oxidation, or thermal stress. In those cases, filtration is protecting pumps, valves and actuators, but also helping preserve the condition of a higher-value fluid. That can influence media selection, seal material compatibility, element construction and the use of offline filtration or fluid conditioning to extend oil life.
In addition, some zinc-free hydraulic oils may have relatively low electrical conductivity, which can allow electrostatic charge to accumulate as the fluid passes through the filter media. In certain applications, a discharge inside the filter could damage the media, contribute to oil degradation and varnish formation, interfere with sensitive electronic components or create other system risks if not properly addressed.
To help address this challenge, Eaton offers IS27 electrically conductive filter elements for applicable E, NL and NR lubrication-filter designs. These elements incorporate a continuous metallic path — including a metal center tube, metal end plates or receptacle rings, and metal axial-fixing rings where required — intended to dissipate electrostatic charge through the filter housing when properly specified and installed.
The IS27 specification also excludes anodized aluminum and, for specified media configurations, prohibits nonmetallic coatings on the pleat bellow, which can help reduce electrostatic-discharge risk and protect both the fluid and the system.
These fluid-specific challenges do not necessarily require a wholesale redesign of the filter, but they do call for a more application-specific approach to element construction, media selection and system configuration. Before we can suggest a filtration strategy, we need to know the fluid chemistry, the desired level of cleanliness, the operating environment and how sensitive the components are. The goal is to protect both the equipment and the fluid.
Power & Motion: How does Eaton see hydraulic filtration technology continuing to evolve in the next 3-5 years? What further technological developments may come to market in the years ahead?
Cory Gray: Hydraulic filtration appears to be moving from passive component protection toward more active fluid-system management. We expect next-generation technology to help operators better understand contamination, control it and keep systems running more predictably.
One likely area of evolution is condition monitoring, where customers may increasingly want a fuller picture of system health: particle counts, water content, temperature, viscosity effects, flow behavior and filter loading trends. The value is not just knowing that an element is clogged but understanding how quickly it is loading, what that may indicate about contamination generation and whether the system is drifting away from its target ISO cleanliness level.
That may push filtration closer to predictive maintenance, so that instead of changing elements on a calendar interval, operators can use sensor data, oil analysis and machine operating data together to help determine when service is needed. Over time, that data may also help identify root causes that contribute to failures, whether [that be] abnormal wear, ingression, poor reservoir management or fluid degradation.
Automation is another important direction, particularly in high-duty-cycle hydraulic and lubrication systems where stopping flow is not practical. We expect continued adoption of duplex and changeover filtration architectures, especially in lubrication systems, high-flow return circuits and applications with elevated contamination loads.
That broader shift also requires engineers to think beyond particulate filtration alone. Water and entrained gases can harm hydraulic and lubrication oils in ways a conventional filter element cannot, so fluid purification is becoming increasingly important.
Eaton’s IFPM 10 is an automatic offline fluid purification system based on vacuum evaporation that removes free, emulsified and dissolved water and free and dissolved gases. The dehydrated fluid is then passed through an integrated spin-on filter for particulate collection before being returned to the reservoir. By removing water, gases and particles in one offline process, this system can help support fluid service life in applications where wear, corrosion risk or space constraints are important considerations.
The next step may be to connect filtration and fluid-conditioning systems more closely to machine controls, typically via PLC, SCADA or other smart-control tools. Differential pressure, flow, temperature and contamination data could then be used to support condition-based maintenance alerts, identify restrictions and respond to fluid condition or filtration performance issues before they become critical. The goal is to maintain stability in a dynamic environment, support fluid and component life, and reduce operational risk associated with manual, reactive maintenance.
Sara Jensen
