Piston Seals Do Their Job
Series 714 double-acting piston seals from Hallite Seals America feature reinforced, heat-stabilized, thermoplastic sealing faces, equipped with a step-cut joint to allow easy passage over ports.
Series 714 double-acting piston seals feature reinforced, heat-stabilized, thermoplastic sealing faces, equipped with a step-cut joint to allow easy passage over ports. A concentrated, tangent contact patch lies beneath the sealing face for dynamic sealing ability. The series is designed to prevent piston-to-bore contact in high-pressure applications with large extrusion gaps, and are well-suited for double-acting telescopic cylinders. The profiled nitrile-rubber energizer material can also be changed for different media and temperatures.
Hallite Seals Americas Inc., (248) 668-5200
Leah Scully
Associate Content Producer
