Push-to-connect fittings
A line of push-to-connect pneumatic fittings allows instant connections by simply pushing the tube into the fitting. Available in a range of body designs and configurations from 1 /8 to 1 /2 in. in diameter, the fittings come in both poly and ...
A line of push-to-connect pneumatic fittings allows instant connections by simply pushing the tube into the fitting. Available in a range of body designs and configurations in sizes from 1/8 to 1/2 in., the fittings come in both poly and nickel-plated brass. The fittings are also offered for metric tubes with BSP threads in taper, parallel, and metric form.
Brennan Industries Inc.,
(888) 331-1523,
www.brennaninc.com
