Pressure transducers
Pressure transducers built for rugged applications. All-welded pressure sensor located directly in the stainless-steel pressure connection to prevent damage. Sputtered thin-film sensor has high overpressure capability, along with high shock and ...
Pressure transducers built for rugged applications. All-welded pressure sensor located directly in the stainless-steel pressure connection to prevent damage. Sputtered thin-film sensor has high overpressure capability, along with high shock and vibration resistance. Available electrical outputs include current and voltage, as well as a low supply voltage version.
Noshok Inc.,
(440) 243-0888,
www.noshok.com
