Stainless-steel cylinders
ICS cylinders are available in 304 and 316 stainless steel and lubricated with food grade grease. Smooth surfaces and no cavities/dead spaces allow easy cleanup. Bore sizes range from 25 to 100 mm. Threaded end caps increase life expectancy and simplify ...
ICS cylinders are available in 304 and 316 stainless steel and lubricated with food grade grease. Smooth surfaces and no cavities/dead spaces allow easy cleanup. Bore sizes range from 25 to 100 mm. Threaded end caps increase life expectancy and simplify repair. "Ideal cushioning" allows fine tuning of cushions to maximize stroke speed, resulting in reduced cycle times, reduced vibration, and longer cylinder life.
Bosch Rexroth Corp., Pneumatics Technology Group,
(859) 259-3852,
www.boschrexroth-us.com
