Volume booster
Type 6000 high flow volume booster delivers high air flow capacity and fast action throttling control. It is available in aluminum or 316 stainless steel. Maximum signal pressure of 150 psig provides output pressure to 150 psig with flow of ...
Type 6000 high flow volume booster delivers high air flow capacity and fast action throttling control. It is available in aluminum or 316 stainless steel. Maximum signal pressure of 150 psig provides output pressure to 150 psig with flow of 115 scfm. Choice of 1/2 or 3/4 in. NPT output ports provides plumbing flexibility for easy hookup. Integral bypass valve provides stability and allows normal position airflow and valve actuation.
ControlAir Inc., (603) 886-9400, www.controlair.com
