Heavy-duty cylinders
MH air cylinders feature all steel construction and are rated to 250 psi. They come in bore sizes from 11⁄2 to 24 in. and are internally lubricated for life. A repairable, floating, and self-aligning rod cartridge compensates for misalignment ...
MH air cylinders feature all steel construction and are rated to 250 psi. They come in bore sizes from 11⁄2 to 24 in. and are internally lubricated for life. A repairable, floating, and self-aligning rod cartridge compensates for misalignment and extends rod cartridge life. They come with long-lasting Nitrile seals and a cushioning system with captive cushion screw. "Slip tuff" coated rod cartridge for side loading and linear transducer position sensing are available.
Peninsular Cylinder Co.,
586-775-7211,
www.peninsularcylinders.com
