Plug-in air valves
CD26-PL manifold system is 26 mm wide and offers flows to 1.01 Cv. Simultaneous pneumatic and electrical connection is done on base plate. Threaded manifold ports come in NPT and ISO-G. Single and double solenoid and double 3/2 valves allow two ...
CD26-PL manifold system is 26 mm wide and offers flows to 1.01 Cv. Simultaneous pneumatic and electrical connection is done on base plate. Threaded manifold ports come in NPT and ISO-G. Single and double solenoid and double 3/2 valves allow two functions from same valve position. Multi-pin plug version with D-sub connector directly combines it with BDC, VDS, and DDL bus systems as well as Profibus, CANopen, DeviceNet, Interbus S, ControlNet, and Ethernet I/P.
Bosch Rexroth Corp., (859) 254-8031, www.boschrexroth-us.com
