Air compressors
Taskair E series articulating piston units have an enclosed permanent magnet dc motor and compressor for long life in harsh environments. They provide up to 150 psi and maximum flows of 3.35 cfm at speeds to 1800 rpm. Oil-less design uses dual ...
Taskair E series articulating piston units have an enclosed permanent magnet dc motor and compressor for long life in harsh environments. They provide up to 150 psi and maximum flows of 3.35 cfm at speeds to 1800 rpm. Oil-less design uses dual cast iron cylinders, high strength stainless steel valves, and PTFE piston rings and skirts. Motor and compressor bearings are permanently lubricated and sealed. Motors are available in 12 and 24 V dc.Thomas Products Div., a Gardner Denver Co.,
(920) 457-4891, www.rtpumps.com
