Temperature sensors
TP200 Series temperature sensor comes in a high-pressure capsule with 0 to 5 Vdc or 4 to 20 mA linear analog output. Available with either #4 SAE, 1/4 in. NPT, or 1/4 in. BSP ports. Temperature range of 0 to 150° C. Measures 3.9 in. long and ...
5 Vdc or 4 to 20 mA linear analog output. Available with either #4 SAE, 1/4 in. NPT, or 1/4 in. BSP ports. Temperature range of 0 to 150° C. Measures 3.9 in. long and 0.86 in. in diameter; weighs 10 oz without mating five-pin connector.
Pressure rating is 6900 psi. Wetted materials are chromed bronze with an aluminum enclosure.
Webster Instruments,
(414) 769-6400,
www.webster-inst.com
