Twin rod cylinders
P5TT and P5TD cylinders offer a small footprint and dual-cylinder bores to deliver maximum force. They come in bore sizes of 6, 10, 16, 20, 25, and 32 mm with stroke lengths from 10 to 200 mm in 5 mm increments. They are available in a single ...
P5TT and P5TD cylinders offer a small footprint and dual-cylinder bores to deliver maximum force. They come in bore sizes of 6, 10, 16, 20, 25, and 32 mm with stroke lengths from 10 to 200 mm in 5 mm increments. They are available in a single or dual tooling plate version and with recirculating ball bearing or plain bushings. They are rated for pressures to 150 psi and have M5 or 18-in. port sizes.
Parker Hannifin Corp., Actuator Division
(330) 335-2141,
www.parker.com
