Software-based control
IQAN-MD3 master module integrated software-based control system incorporates computing with high processing speeds and dual CAN bus interfaces, for use with hydraulic components and input devices, such as joysticks, pedals, and sensors. ...
IQAN-MD3 master module integrated software-based control system incorporates computing with high processing speeds and dual CAN bus interfaces, for use with hydraulic components and input devices, such as joysticks, pedals, and sensors. It withstands EMI, vibrations, and extreme temperatures. It is programmed with 32-bit software platform IQANdesign, for quick and easy writing of machine functionalities and display of tools without specialized programming. It interfaces with IQANrun software, for field service technicians to diagnose problems and conduct maintenance.
Parker Hannifin Corp., Hydraulic Valve Div., (828) 248-4328, www.parker.com
