Fittings with double-seal system
Uniport 10K stops leaks with a double seal (metal-to-metal and O-ring). Completed the most severe testing program by SAE for a fluid connector/port system. Swivel nut eliminates adapters when connecting to components and yields small component ...
Uniport 10K stops leaks with a double seal (metal-to-metal and O-ring). Completed the most severe testing program by SAE for a fluid connector/port system. Swivel nut eliminates adapters when connecting to components and yields small component envelope and light weight. Safe at higher operating pressures, and less chance of over-torque at assembly. Offers simple port geometry.
Fluid Line Products Inc., (440) 946-9470, www.fluidline.com
