Seal flange adapters
Dual seal flange adapters improve the reliability and safety of high-vibration, high-shock hydraulic four-bolt connections in critical subsea oil and gas applications. They are an alternative to traditional SAE Code 62 flanges. They are available in ...
Dual seal flange adapters improve the reliability and safety of high-vibration, high-shock hydraulic four-bolt connections in critical subsea oil and gas applications. They are an alternative to traditional SAE Code 62 flanges. They are available in standard Code 62 footprint sizes (-8), 1 (-16) and 1 in. (-24), and incorporate both radial and face sealing for improved port retention and increased sealing capacity. This helps reduce the potential for system leakage and air/water ingression caused by side loading of conventional flange face seal connections. They have been tested to 7500 psi with a 4:1 design factor.
Parker Hannifin Corp., Tube Fittings Div., (614) 279-7070, www.parker.com/tfd
