Clamping connections
Hose and tubing clamps assure leakfree sealing and fastening for all clamping and pressure ranges, hard or soft materials, hoses, cables, or ropes. Permanent, tight connection only released if required. Made from tube or band, stepless, ...
Hose and tubing clamps assure leakfree sealing and fastening for all clamping and pressure ranges, hard or soft materials, hoses, cables, or ropes. Permanent, tight connection only released if required. Made from tube or band, stepless, self-tensioning, or reusable. Available in rust and acid-resistant materials. Offered in metric dimensions.
Oetiker Inc., (800) 959-0398, www.oetiker.com
