Multi-plate quick-connection
Multi-X easy-to-handle multiplates connect multiple hydraulic lines in one single operation. Six standard configurations match the most frequent applications: sizes from DN 10 to DN 19, with two or four ports in each plate. They are rated for maximum ...
Multi-X easy-to-handle multiplates connect multiple hydraulic lines in one single operation. Six standard configurations match the most frequent applications: sizes from DN 10 to DN 19, with two or four ports in each plate. They are rated for maximum working pressure of 35 MPa and minimum burst pressure of 120 MPa. Female plate can come in Zinc-plated steel, anodized aluminum, zinc, and brass while male plate is available in zinc-plated steel, anodized aluminum, and brass. Seal is composed of Nitrile (NBR).
CEJN Industrial Corp., (847) 406-4488, www.cejn.com
