Commercial-grade fittings
Plastic commercial-grade fittings are designed with a single sharp barb and require no tools for insertion. Available in 33 styles, standard fittings are made of nylon and polypropylene. Fittings made from heat-stabilized nylon, ...
Plastic commercial-grade fittings are designed with a single sharp barb and require no tools for insertion. Available in 33 styles, standard fittings are made of nylon and polypropylene. Fittings made from heat-stabilized nylon, high-density polyethylene, polycarbonate, Kynar, and acetal are also available. Nylon fittings can be color coded to match application. They provide a leak-proof seal at pressure to 125 psi without using clamps or ties.
Ark-Plas Products Inc.
(870) 453-2343
www.ark-plas.com
