Leak-tight fittings
Gaugeable tube fittings and adapter fittings provide leak-tight sealing and vibration resistance to 15,000 psig (1034 bar). Available in 1/4-, 3/8- and 1/2-in. sizes, the all-316 stainless steel fittings come in many configurations, including elbows, ...
Gaugeable tube fittings and adapter fittings provide leak-tight sealing and vibration resistance to 15,000 psig (1034 bar). Available in 1/4-, 3/8- and 1/2-in. sizes, the all-316 stainless steel fittings come in many configurations, including elbows, unions, bulkhead unions, reducing unions, tees, crosses, caps, and plugs. Proprietary hinging-colleting action grips and seals the tubing securely with no special tube preparation required.
Swagelok Co.
(440)349-5934, www.swagelok.com
