Tie-rod cylinders
Powder-coated tie rod cylinders are available in many models with pressure ratings to 2500 psi. They feature forged rod clevis and base clevis mounting. Plated tie rods and powder coat allow coverage under the tie-rods.
Powder-coated tie rod cylinders are available in many models with pressure ratings to 2500 psi. They feature forged rod clevis and base clevis mounting. Plated tie rods and powder coat allow coverage under the tie-rods. They come with ½ in. NPT ports, bore sizes from 2 to 3 in., and stroke sizes from 4 to 36 in.
Prince Mfg. Corp., (605) 235-1220, www.princehyd.com
