ISO air cylinders
Edited by Alan Hitchcox ISO 6431 compliant air cylinders have adjustable air cushions at both ends and magnetic pistons in seven bore sizes from 32 to 125mm, with strokes to 1000 mm. Machined male rod thread with jam nut also standard. Extruded ...
ISO 6431 compliant air cylinders have adjustable air cushions at both ends and magnetic pistons in seven bore sizes from 32 to 125mm, with strokes to 1000 mm. Machined male rod thread with jam nut also standard. Extruded aluminum cylinder tube has hard anodized ID and OD for corrosion resistance and long life. Lubricated air not required. Optional position sensor mounting brackets fit over any of four housing rails.
Fabco Air Inc., (352) 373-3578, www.www.fabco-air.com
